SFF Cables
Vashypooh
Hi all,
I have a backup server that we use at work, that I used onboard motherboard raid at the time as it is all we had. This presented an issue because it only supports 4 drives in a raid 10, and I have 6 drives. So two are unused.
I came across a dell H310 PCI card today in a machine, that doesn't need it, not sure why it even had it, and want to put it into that server so I can get full performance (RE: storage) I had planed on, 6 3tb drives in raid 10. The problem being, I have no i dea what I need to swap it into the Supermicro.
Does this cable seem right? I would need two of them. (I already know I need a low profile backplate for this card, and can get one)
http://www.monoprice.com/products/p...=10254&cs_id=1025406&p_id=8187&seq=1&format=2
References:
Card:
http://www.ebay.com/itm/Dell-HV52W-...sk_Controllers_RAID_Cards&hash=item4d0d9400bf
http://i.dell.com/sites/doccontent/...heets/Documents/dell-perc-h310-spec-sheet.pdf
Supermicro:
http://www.supermicro.com/products/system/2u/5026/sys-5026t-3f.cfm
http://www.newegg.com/Product/Produ...pk=SUPERMICRO SYS-5026T-3FB&IsVirtualParent=1
Yes, that is the correct cable.
It won't id the failed drive though, but not sure that case supports that anyways.
I don't nessecarily need it to do that, I already know by serial # which is in which.
Thanks for the help. I will place an order tomorrow :]
