First post ever here,
I've built several systems before, including a SFF and it's time to upgrade. I've learned through hard experience that you have to be careful if you want a stable yet powerful SFF, so I've come to you guys. Here are the things I'm definitely using (unless you feel strongly against):
Case: Apevia X-QPACKII
Processors: Core 2 Duo E6700 or 6600 (depends on prices when I finally pull the trigger)
Video Card: Nvidia 8800 GTS (320 or 640, again depends on #'s when I pull the trigger)
The rest is where I need help, especially on mobo and RAM. So please, give me your recommendations on mobo, RAM, if you think I shouldn't use stock heatsink/fan, hard drive, dvd drive. Keep in mind I'm looking for that sweet spot between stability, price, speed, noise and heat.
I would really appreciate any recomendations! Thanks,
Dan
Dan
