SFF build for HTPC/GAMING
ShafTDawG
Hi all. I was just wondering if a Scythe Ninja-mini will fit in a Silverstone SG-01 case. I will be using a DFI Lan party jr. motherboard, and I was wondering if I will be having any clearance issues.
Also, will the GTX 260 fit in the case?
I'm planning on hooking the pc up to my hdtv, and I was wondering if I will be able to output sound from the vid card (using a DVI to HDMI cable to the t.v.) with a small cable from my sound card to the vid card. If so, what kind of cable is it so I can purchase it before I start the build.
Specs of the comp will be:
DFI Lanparty Jr P45 chipset
Intel e8400 - dont know yet if I will be overclocking, probably a bit
4gb ddr2 pc-6400 memory
2 x 640 GB Western Digital Caviar Black HD
Corsair 620W PSU - this one: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139002
Scythe Ninja Mini HSF
XFX GTX 260 Core 216
Any thoughts? Suggestions? Violent reactions? I'm going to be ordering the parts in the next couple of weeks, and all inputs are appreciated.
Your system specifications are solid except for the case selection. The SG-01 will only permit a maximum of 82mm heatsink. The Ninja-mini has a height of 115mm.
Many have installed the Ninja-mini into the Lian-Li V350 (also new 351) to great success.
If you are set on the SG-01, further heatsink research is warranted.
Good luck.
Yup, I just noticed that too, and have decided to go with a silverstone nt-06 lite. From what I've read, this cooler is going to be just right for the case. Also, it seems as if the gtx 260 will not fit without any mods to the case, so I'm going for the 4870 right now.
