Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I am looking @ building a small computer since the one i have now is way to big. I want to build a SFF computer. What are some you guy can recommend some?
I have a shuttle computer. Its worked great for me for the last year and half and I love it. Some might complain its a little loud but it hasn't bothered me at all, I can sleep through it. If you're looking to build from a barebone, I'd recommend a shuttle. Keep in mind though, that it doesn't use a normal mATX board, its custom specific to each shuttle, but it does its job just fine. Another thing to keep in mind is that larger video cards wont fit without some modding and SLI I wouldnt try in a shuttle.
if you re looking to move your s754 gear into a smaller box, you can probably find a soltek, shuttle, biostar ideq, or something similar with the appropriate socket. I would check sffclub.com or sfftech.com for more info about available barebones.
