SFF and your GPU won't fit?
G'ßöö
I have a SN95G5 and a leadtek 6800 (OCZ 3200 plat rev 2 anda a64 3500) and am toying with where to go with the design. To retain a proper SFF system I think all components must remain within the rig cause it must be packed to lan's with ease. I see some pics out there but there must be more? Not wanting to water cool, how are people moddin the GPU side? pics!?!?!? issues?
Cheers!
are there any replacement hsf's out there that are slim enough enough to make this work without a side mod? ideas? issues? I guess the main issue for me is do I want to hack the case up or find a workaround....
I know of no slim 1 slot design 3rd party coolers. The Arctic Silencers are two slots and I haven't seen a Zalman model yet that may work. Until such time, your stuck with the stock HSF's.
A few peeps wanting dual slot coolers have simply sliced open their side panels. Ugly, but effective
well...I didn't wanna say this but no one has so I will...
yea that's FUGLY!! heheh sorry had to but I understand :D . mine runs without a case so you're better off than me....kinda? HEHEHHE
There's Vantec Iceberq4's... they perform ok, nothing stellar, but on a 9600, it can run on really low rpms (through speedfan)
I decided to see how fugly mine looks with just the outline of the leadtek hsf cut out and I can easily say that's not the best lookin or functional way to go. The whole side needs to be extended out with some kind of tough guard allowing airflow. I did however get the satisfaction outta cutting 'er up with the dremmel
cheers!
The mesh is ugly, but am I the only one who actually LIKES the look of the Silencer sticking out the side? That could actually be done nicely in an actual mod project I think....hmm..... ;)
I might have to pick up a cheap, used Shuttle to paint and throw a 9600Pro or something in and "make" that Silencer fit kinda like the above pic.....could be an interesting project. :p
since you're a canuck, where u getting the mesh from cornelious0_0? vancouver needs a mod store or I just don't know of one...
thnx
thnx
I was planning on getting someone I had been talking with in the states to buy it and ship it next day air for me to avoid customs and international payment processing that I'd have to go through.
the moddermesh faq mentions people walking into home depot asking for this product, however I don't think I've seen it in there.
tracking supplies down sux :eek:
I'll give my local Home Depot a call today and see, if by some chance they do have some that'll save me a LOT of trouble, and i'll maybe hook you up with some too. ;)
good on ya! my cubie mate says he use to work at home hardware and they stocked this kinda thing...the jury is still out cause I've been to them both stores quite a bit and never saw any. I best enquire again..
Would an X800 fit? I would try that. Even if it does, it looks like the airflow would be completely cut off, unless you open the case.
ARIA is not the best looking or smallest looking case, but it gives you more flexibility and the ability to keep all of your mods, next time you upgrade. Main thing is, you don't blow $200-300 in lost resale value when you cut a freaking hole in the side of your case for a proprietary mod, like a VGA Silencer! I would seriously give the ARIA a look.
sleepeeg3 said:
Main thing is, you don't blow $200-300 in lost resale value when you cut a freaking hole in the side of your case for a proprietary mod.....
BA! $$ was meant to be spent. it's all about the mod! :D. I agree with cornelious0_0, I like the GPU out but I want it to look retail
Yeah, it does look nice, but the job that was done on that particular SFF just kills it. :p
Of course it'd fit. Much to my surprise, I used to have my 9800XT installed in my old SB65G2 and it really didn't hurt the temps and overclocks AS much as you'd think. The panels themselves were very warm to the touch though, I'd still recommend having the panels off or doing mesh windows in 'em if you're gonna install an X800 though. ;)
"kills it" is a friendly way of putting it. am sure most would use a more colorful explanation :D
hmmm...a list of what and will not fit cause so many ask? I know of 2 that won't. Other than that I think they all fit but I am by no means a [H] kiosk
6800GT ultra (all brands?)
6800GT by leadtek
6800GT by leadtek
I could have sworn there were one or two single slot Ultra's out there, Asus comes to mind. Also, I can't quite remember if Gigabyte's fanless 6800NU is a single slot or not, looks like the heatsink on it rises up a bit to high.
I see mnpctech has the mesh up again, now in bigger sheets. I ordered two and I think I like this design of this best. the mesh under plexi and some design (no dog though)
The plexi/mesh look is still alright, and better if someone is on air cooling that rely's on that airflow that would be lost in a completely open mesh window'd case.
that circular mesh just doesn't do it for me though.....not open enough. ;)
