There's two ways air can enter, the top or the front (120mm intake fan at the top, cpu heatsink intak in the front), and one way to exit (80mm psu exhaust). What has me worried is that little fan trying to pull air out of the case.
I know how these sff systems like to get hot, so everything will be at stock speeds... unless the temps allow for overclocking, then I will maximum power this little monster
Keep in mind that while the GPU and CPU Heatsink are to scale, the rest may be off by ~.5". Also, the "separator" is actually part of the case, I just had to lower the opacity of the outer chassis to make things visible. The gpu connects to pcie x16 slot via riser, oh, and keep the laughter to a minimum please, this is my first time using sketchup
Zotac GTX 660 Ti "short" (green)
Kozuti Scythe (blue)
Silverstone 450W SFX Bronze
2x4gb 1600 ram
Mini-ITX motherboard
64GB SSD
1TB Internal
2x4gb 1600 ram
64GB SSD
1TB Internal
