SEX & running too hot...
PureMajik
Now that I got your attention...I have a xp 3000+ with a Thermaltake VOLCANO 11+ Xaser Edition Cooler and I currently run @ 43-44C @ idle...I have pretty ok ventalation in my case...a 80mm in the front with two in the back forcing out the air...What can I get to cool down my cpu...
Don't have sex on your computer case. Problem solved
Edit: Temps don't sound too bad actually. What are load temps? Is this an ABit or different brand motherboard? (Abits read temps differently than others). If you want more cooling, I'd suggest more intake. It sounds like you have 3 exaust fans right now (2 80mm's in the back, plus PSU's exaust) and only one intake, which is really unbalanced... Might mod (or add, if you have free fan slows) some intake fans and see what happens.
