So I put together my PC during October 2010 and it has been running without trouble for years.
Specs: GA X58a-ud7 (rev 2.0) Intel i7 930 @2.80GHz Patriot memory 12Gbytes DDR3 1333LL Series MSI Lightning GTX 680
I have been overclocking the CPU and GPU but have stopped doing so. Everything is at default to find out what is giving me trouble.
About 6 month ago I bought a Samsung SSD 840 Pro 256 GB and while I was at it I installed Windows 8.1 to run on the SSD and used my Velociraptor as secondary drive. I also have 2 WD Caviar Black 1TB running in RAID1
I had several issues and have formatted a few times since, but they always seam to come back. So the SSD is running on the Marvel controller over AHCI, while the rest of my HDD are running on Intel's IDE controller. The SSD is actually connected to the Marvel controller over GSATA (SATA3 from Gigabyte)
The Marvel controller was installed correctly before installing Windows, although I had some trouble. In order to make it work better I updated my BIOS to the latest possible version, which is FC. I can not instal the FD version since it's size is to big (only have 1MB BIOS and FD is 1,2MB)
I used the Marvel driver from the official Gigabyte mobo website. Although when searching for drivers or software on the site the only options are Windows XP/Vista or Windows 7. So that made me think the mobo is not compatible with Windows 8.1 Still, from Microsofts side there seams to be no problem in using Windows 8.1
Now to the issues at hand, inside Windows device manager I find the Marvel controller under Other Devices and with an interrogation sign. Although it detects the controller and tells me it is working fin it does not recognize the provider, date or version.
And it gets weirder, when I go in to the Devices and Printer window the Marvel Controller shows up under Other Devices. I even find the Marvel controller and the Samsundg SSD in my taskbar, when removing USB connected devices.
I also noticed the Write/Read speed is not the same as the one mentioned by Samsung and different reviews, I guess that has to to do withe the Marvel controller and the GSATA. So at this point I don't really know what is happening and how to fix it. There is apparently nothing wrong with the SSD, still it is strange and might be connected to the second issue I'm having.
The next problem are USB ports. When I boot, every HDD or flash drive connected will be detected and I can use them without trouble. But once inside of Windows any newly connected Drives over USB will not be detected. This applies also to wireless headphones that connect over a Bluetooth dongle.
Furthermore, if I try to open up the Devices and Printer Window the Control Panel does not respond and I have to restart Explorer from the Task Manager. I have set my Power Configuration to High Performance and turned of the Power Saving for USB, but this does not help.
Last but least, Rebooting or shutting down does not work. If I reboot, the reboot screen pops up and keeps at it for a while and I guess at some point the PC just decides to reboot. If I shut down the PC, Windows closes and the screens turn off but my machine keeps running. I also noticed that I'm having trouble getting into BIOS at startup, this might be because I use a Keyboard connected via USB.
All of this goes away as soon as I format the whole thing and than it is just a question of time before the problems show up again. So I really would like some opinion on what is going on, is it the SSD, is it Marvell or is it al because of Windows 8.1
