I need to build a server for a large format printer, and since I don't generally do server builds, I'm looking for some guidance... mainly on the processor, motherboard, and memory side.
Here are the specs I was given:
OS: Windows 7 Pro (64bit)
CPU: 3.33 GHz 6-Core Intel Xeon Westmere (preferably more processor cores),
RAM: 8GB RAM,
Hard Drive(s): 1.5 TB 3 GBit/Sec. Serial-ATA with 7200 rpm or more. Ideally 4 hard drives, minimum 2 hard drives, should be routed via Server File Maintenance in the Fiery XF Client as follows: 1 connected via SATA for the job folder, 1 connected via SATA for temporary files, 2 connected via Raid 0 for the output folder.
So basically, those are the minimums I am working with. I just want a build that fits these requirements without me making any dumb mistakes since I generally just build desktops
RAM: 8GB RAM,
