I am planning on converting my old AMD 64 X2 4200 with 4Gb of DDR 2 Ram PC3200 into a Windows Home Server. I have alot of Storage space currently 11.7 TB. I want to make this computer a host for all my DVD's that i am backing up and other assorted files, along with utilizing the back up feature of WHS to back up my many computers inside my home. I want to be able to retrieve files remotely off of the LAN and back up files/computers on the LAN.
My internet connection is through COX cable and is the mid line connection plan. My Connection is Wired, I have a Linksys Router that is connected to a Switch which is connected to my Wired Devices.
My server hard drives will be a mixture of WD Green 2 TB 64MB Cache and a few 1TB WD Blue Drives as well.
My Current Rig is As Follows
Case Thermal Take Armor
Mobo ASUS - A8N32 SLI Deluxe 939
CPU AMD 64 X2 4200 (I believe thats the right name for it.... Its a Dual Core @ 2.2Gz I think)
Ram Patriot 4GB (4X1) DDR2 PC 3200
I have a few questions regarding Hardware.
1. Is Upgrading NIC card worth it, and if so which would be the best "Budget Upgrades" ?
2. I am out of sata connections inside the case, I have looked at controller cards, and at this time Raid is not a big concern I am just looking to expand my storage inside this case what is a decent Sata Controller Card (3.0 Sata II). I do have a PCI Express X16/X8 slot open. (4+ slots would be a Big Help)
3. I have some money to play with and could potentially put it into some hard ware upgrades CPU/Ram/Mobo. Is it needed for what I am doing or can I get away with what I have. If it is needed What would be some suggestions. I have a 2-300 Dollars I can play with if there are upgrades to be made,
Thanks in advance for any suggestions that are made
