Hi guys...well, hopefully, my new PC parts should be arriving in a few days now, so I thought I should do some revision, on how the fitting goes for the specific items that I have ordered...
The items I have ordered are listed in my Profile....
I am specially looking for an installation guide for the casing: Aerocool AeroEngine II Casing....
Also I have some basic questions regarding my first build:
1) Can someone please tell me the difference between the S/PDIF in/out connectors and the 6 colourful connectors, all on the port side if SLI-DR..
2) It has been mentioned that its better to assemble the motherboard outside first, and the move it into the casing.......if I do this, the components attached on board might get sudden movements/jolts when I am shifting about the mobo inside the casing, to fit it in....wouldnt these movements cause harm to the components attached ??
Thanx in advance....
EDIT: Also, if you happen to have manuals (preferably in PDF format) for any of these items, please send them my way
