MOBO: ASUS P8Z77-V Premium
I'm trying to cache the 32gb SSD in the mSATA port to a HDD. I've found out that have to use the Intel SATA port to connect my HDD to cache the mSATA SSD to it. Then I'm suppose to use the Intel Rapid Storage Tech software and click the "Accelerate" button to set it up. Unfortunately, I don't have that button. So researching some more, I've got to enable RAID in the BIOS to get that button. This is where I start running into problems.
To preface the problems, I've got my boot drive plugged into the marvell SATA ports. So I would think enabling RAID in the BIOS wouldn't effect that since it only lists the stuff plugged into the intel ports.
First problem, as soon as I turn RAID on, Windows will not boot anymore.
Second problem, I don't know what to do in the RAID menu that you get to by pressing CTRL+I.
Please HELP!
Please HELP!
