R
ring.of.steel
Guest
hi,
i would like to setup a caching dns server as the one provided by the isp is slowwww. what hardware would you recommend me using? will a pIII 500 be enough?
apparently the packages i need are
how would i configure the server to cache all dns queries and autoflush after 2 weeks? also would i notice a difference compared to the isp server with general browsing. i have a dynamically assigned ip by the isp if this matters.
thanks
Code:
[LIST]
[*]bind (includes DNS server, named)
[*]bind-utils (utilities for querying DNS servers about host information)
[*]bind-libs (libraries used by the bind server and utils package)
[*]bind-chroot (tree of files which can be used as a chroot jail for bind)
[*]caching-nameserver (config files for a simple caching nameserver)
[/LIST]
thanks
