I just got a wireless router (Buffalo WHR-HP-G54) and I tried replacing my old wired router with it, but it would not work, because of the location, which is too far away to get good signal strength in most of the house. So I had to plug the new router into an Ethernet jack in my house, so now we are kind of using 2 routers. I have heard this can cause problems, so I wanted to make sure I am doing everything right (I haven't noticed any problems yet though
I hooked up the new wireless router to the Ethernet jack after putting it in "access point mode" by following the instructions on page 14 of the manual (http://www.buffalotech.com/support/getfile/?WHR-HP-G54-Manual-v1.7-web.pdf) so I hope I did that right... or was I supposed to follow the instructions to use it as a bridge/repeater?
I should note that I want to use the new wireless router to get wireless all around the house, and to also plug in a few wired Ethernet cables to run to 2 computers in the house (this is on top of 3 computers and this new wireless router which are plugged into the old wired router). Thanks for the help.
Here is a crudely drawn diagram of my current setup:
