Hey guys,
This is driving me crazy. I decided to move my m0n0wall router into a VM so I could get rid of a physical computer at home (thinking it would be relatively simple), but it's not as easy as I thought it'd be.
Right now I have my DSL modem hooked up to a physical NIC (eth1), which is bridged to vmnet1, and my LAN is hooked up to a different NIC (eth0), and bridged to vmnet0. I told m0n0wall which virtual interface is which, and now I have a "working" dhcp/nat server.
Here's the issues I'm trying to solve:
1. Since my WAN interface is bridged, both the guest and the host are grabbing different external IPs. This isn't a big deal, except for the fact that it adds unnecessary confusion whenever I have to troubleshoot something. I'd like the entire network to have one external IP and have everything else NATted to it.
2. m0n0wall is protecting my network just fine, but the host computer running it is wide open. Right now I have sshd and all the vmware services exposed to the outside world, which I really don't want. I know the solution is iptables, but I have zero experience with it. Any guidance would be appreciated
and finally,
3. For some reason, all the ports that are forwarded inside m0n0wall are still blocked somewhere in the network. I'm guessing the host is blocking them? I used the simple uTorrent port forward check, and it fails. I know m0n0wall is set up correctly because I based my config on a working one. This is the biggest problem I have right now that I'm trying to fix. Any hints?
So, basically, I'd like the host to be completely transparent right now. How can I achieve that?
Thanks in advance,
KodeK
EDIT: I think #3 was my stupid mistake. I forgot to renew my desktop's dhcp lease to match the IP to the one I had on the firewall. My desktop's connection dropped and as soon as it came back up, the port was "automatically" forwarded. Would this make sense? (Router checked lease, and since IP didn't match the reserved IP, it renewed the lease. Would it make my desktop drop all of its connections? If so, is this logged anywhere? I'm running Win7.)
and finally,
Thanks in advance,
KodeK
