Setting up ICS with LanParty NF2 Ultra
Deque
I was wondering if it's possible to use the second LAN port on my DFI LanParty board to allow my Xbox to get online? I have a router, and my PC is connected to it fine, but it would save me a lot of wires to not have to run more wires from the router to the room with the PC/Xbox. Plus our Linksys router only has 4 ports, but we can always plug in the Cisco if need be.
I assume the way to do what I wish to do is through ICS, but when I go to Network Connections in the Control Panel, I have 2 connections listed; one is the local area connection, and one that says 1394 Connection, with the quote being 1394 Net Adapter underneath it.
Unfortunately, the local area connection doesn't have ICS listed under it's properties, but the 1394 connection does, but that kicks my computer offline, and doesn't allow my Xbox to be online either.
Also, why did it pick up my second adapter as a firewire connection?
