So I am attempting at setting up a home FTP server, specifcally SFTP since I don't want prying eyes in my business.
So I have since installed Cerberus FTP http://www.cerberusftp.com, chose port 3535 to represent the listening port, created an account on Dyndns, and forward ports 20 and 3535 to my machine (which would be 192.168.1.150). My router supports DynDns, so that is all setup as well.
I know my dyndns works properly because I can remote desktop into my machine which is perfectly successful.
In Cerberus, I enabled the SSL and created a certificate.
I then used (on another computer) WinSCP to connect to my newly created SFTP server on my home machine. I used host (myname.dyndns.org), port 3535, and the appropriate username/password. I then hit login and it appeared to make a connection.
Cerberus on my main machine picked up a connection was getting established...but it never went further...and the WINSCP connection I had timed out.
So something isn't getting through or established. Based on all that info, any thoughts as to why? The Cerberus installation setup said that Port 20 needed to be forwarded for outgoing traffic (which as stated above, I did).
Thoughts?
Thanks
Thoughts?
Thanks
