S
SirKenin
Guest
This is driving me crazy. A client has a D-Link professional grade router, but it has the same problem as all the cheapos. It has a fixed subnet of 192.168.1.xxx. There is no way around this unless you use the DMZ, effectively eliminating the firewall. In and of itself that would not be a problem. HOWEVER...
This office has all their machines on the same subnet. The IP of the second NIC is 192.168.1.100. All of the machines are on DHCP and of course use the same subnet. The copiers, the presses, the RIP server, EVERYTHING is on this same subnet.
So. Here is the problem. When I try to manipulate the computer into giving the WAN port an IP in the same range, the internet connection dies. I can give the IP to one or the other, but I can not give an IP in the same range to both or the incoming connection pukes.
I think I need to move the WAN IP to a different subnet in order to get this to work, but I have spent two hours of my time trying to manipulate this router and server into allowing me to do it and it won't let me.
I really need something to work here and I urgently need suggestions before I go back to the site next week. I appreciate any help you can give.
