D
Deleted member 21895
Guest
Okay, so I just got a new computer and the graphics card im running it through is a 256mb pcie x800 XT with dvi/vga/tv out..
anyway, i have the crt going through a dvi>vga adaptor (since i dont have a dvi lcd) and it works fine... however, the second I plug in the lcd into the other vga port the primary crt monitor goes off.. the only way to get it to come back on is to restart the computer with the lcd unplugged...
i've tried switching the lcd to the dvi port but it still doesn't work... now I used the lcd on my older computer just 2 or 3 days ago (as a primary monitor) and I didn't have a problem with that...
are there any drivers or anything that I need to update? Maybe some graphic card drivers I need to update? I just find it odd that the second i plug in the lcd it shuts off the crt...
also, I haven't gotten the lcd to work at all, that includes by itself on both ports...
Ran through the windows help stuff and it suggested updating bios, graphics card drivers etc... any thoughts?
