- Oct 17, 2000
It's been a long time since I used a water cooling solution, but I finally got it all together, I'm just not sure I have the proper method for the fan and pump/plug configuration.
So as per the Corsair and Gigabyte manual's, I tossed the pump plug into the boards CPU_OPT plug. The 2nd cable from the pump that has a Y splitter, with 2x 3 pin connectors, I figured both the rad fans plug into that...? anyways, I fired up the system, went into the Bios and set the CPU_OPT speed to full for the pump. Both the rad fan's connected to the Y splitter from the pump are both running, but I'm curious if that is the correct way to connect them, going through the Y splitter from the pump as appose to connecting the fans to the CPU_FAN header beside the CPU_OPT...or system fan headers?
Also, CPU temp is reporting 39/40c... it's the 7700k, so is that a normal temp to expect on water, idling in bios? I was expecting temps of 20c idle on water... but it's been a while since I've run water so maybe my expectations were high.
Memories of running my 533 Celeron @ 1GHz using a Peltier cooler
