I picked up a WRT54GL a week or so back after someone recommended I pick one up instead of picking up a PCI wifi card and external antenna to pick up a relatively week wireless connection.
A bit of background info: I live in a park of apartments owned by my university. They came up with the ingenius idea to install wireless APs through the park, so residents could pick up a wireless connection in their apartments and they wouldn't need to run ethernet through all the buildings. Great, right? Yeah, except they ran out of money in this project and the APs are not powerful enough to penetrate into the apartments and give a strong signal. So this is where the DD-WRT enabled router comes in.
I don't have a whole lot of experience with wireless network, outside of setting up small home networks in the past. I messed with the DD-WRT firmware a bit, and have successfully bridged the network to one of the wireless APs in the apartment complex. Only real problem with that is I'm fairly certain they don't want me doing that because they have no control over my router if it decides to go a bit batshit crazy. I'm willing to do it if its my only option, though I can only get 10mbps (if even that) when transferring files from my computer to another through the access point. I'd like to setup the router to essentially be like any home router, but instead of using the WAN port to get its Internet connection, it'll use the AP signal I set.
I'm not sure if I'm being entirely clear, and I'm definitely not sure if what I want to do is even possible. I'm not really sure what I should be looking at settings wise to do this, assuming it is possible. If I need to clarify what I'm trying to do further, I'd gladly do so.
