Description:
I am thinking about setting up a file server in my house to store all sorts of data. I want to put all my documents, pictures from my digital camera, drivers, computer game image files and dvd image files on this server.
I have about 40 DVDs and probably 50 or 60 computer games so this would require maybe 450 gigs (being generous). A lot of the games are old so they may not use too much space and I probably wont play them ever again but it will be nice to have them all in a central location. Then I probably have 5-10 gigs worth of documents pictures and other various accumulated stuff I should keep.
Storage needs:
Image files: 450 gigs
Docs and Pictures: 5-10 gigs
Hardware:
(parts I have laying around or in lightly used computers)
Motherboard: MSI KT3 Ultra ARU (via kt333 chipset socket A)
Processor: 1.33 GHz t-bird
RAM: 256 MB Corsair PC2700 (enough?)
HD: 40GB Maxtor 7200 rpm
2x WD 80GB JB drives (from office max for $20 like 4 months ago)
Optical: DVD-ROM
Video: Old 4meg agp card
Network: IBM 10/100 nic with intel chip
Case: My first computer case black mid tower 5 3.5 bays 3 5.25 bays pretty roomy
Software: I can get windows server 2003 for free through my schools msdnaa program so I think this would be the obvious choice. Maybe Linux would be better though?
PSU: 350watt for now, ill get a good quality one before I start putting data on
Current plan:
40 gig Maxtor for OS
2x80gig WDs for a RAID1 array using the onboard controller for documents and pictures
3x250gig in windows 2k3 software RAID5 for image files (will buy soon or maybe a different size, suggestions?)
Questions:
1 .Since I do not want to spend $500 for a real raid5 controller card I want to use the built in software raid. I assume this is near as reliable as a hard ware solution, it just eats more cpu. Has anyone had problems with software raid5?
2. Will it be possible to dynamically add disks to the raid 5 array? It will only have a 500GB capacity with three drives, so I will most likely need more space as I buy more games and movies. Is it possible to add to a raid 5 array with out having to rebuild it and erase the data?
3. With only 5 3.5 bays I would need to stack the drives right next to each other. I usually leave one bay in between each drive when building computers and have never seen the effects of adjacent stacking. Will there be any heat related reliability problems with the drives? I also plan to add an additional HD rack as needed (maybe put a lianli rack in the case since it is open in the front bottom.)
Sorry for the long post. Comments questions suggestions?
Storage needs:
Hardware:
Optical: DVD-ROM
Current plan:
Questions:
