Guys, I need your help. I know my way around computers but Networking/Wireless Routers and I just don't get along... or so it seems.
First a little bit of History...
1 Server under Win2K Server + 3 workstations under Windowx XP Pro w/SP3. All 3 workstations use the same Accounting Managment Software and until recently, were using AT&T ADSL 6Mbit internet + 6 lines... plenty of problems with Customer Service and them trying to scam us out of money every other month so I decided to change to another provider (Comcast).
The network was run by a Motorola ADSL Modem that was also wireless + a Lynksys 8 port switch (10/100/1000). From MOdem to switch and from switch to Server + workstation to be able to utilize the 1000 speeds. All Ethernet in Server + PC are also 1000 capable.
Changes went well and smooth but I have just a little hickup that I don't know what to do with now.
1.- Comcast Modem
1.- Same Linksys 8 port 10/100/1000 Switch
1.- D-Link DIR-655 Gigabit N wireless router
Network is as follows...
Coaxial cable from outside to Comcast Modem, ethernet wire from Comcast modem to INTERNET port on Router. Ethernet wire from Port 1 of router to port 8 of Switch, all other ports use for the other PC's.
My little issue is the following, Getting to the login of the Accounting Managment Software in the server takes proximately 1 to 2 minutes (something that used to take less than 10 secs before), once we have inputed our passwords, the software seems to be slightly faster than even before (seat of the pants of course).
My friends tells me that he thinks this is because of the security software that D-Links uses, that because of it being moe secure than the one we used to use with the AT&T motorola router, the intiial time is delayed.
Well, like I said, I know nothing about networking but I do know that this is very annoying and I need to do something to expedite this.
Installation of the D-Link router went smooth and after that, I have not been inside it because it is not user friendly at all as the old wrt54g linksys router that I used to have at home.
I am wondering if something can be done with the setting of the router to make hard for hackers to get in but not harder for me to work on my stuff.
Thanks a lot
1.- Comcast Modem
Thanks a lot
