OK, I went ahead and got a heatercore + shroud from dangerden. I know, I know, it would have been cheaper to go to autozone for the heatercore and make my own shroud. I've had lots of little problems getting my WC setup off the ground up to this point, so I decided to go the easiest route.
Well, it's not easy at all. How in the bloody hell does the shroud mount to the heatercore? There aren't any holes in the heatercore for the plastic bolts to slide through. It seems easy enough to screw the fan to the shroud, but how does the shroud connect to the heatercore? Any help would be greatly appreciated.
