cornelious0_0
- Apr 6, 2003
Alright, first off....if anyone is coming at this thread with things in their head like "who would actually care about this stuff" or "this is so pointless" you might as well turn around right now, because i don't expect everyone to understand where I'm coming from here.
Well, with minimal chit-chat...let's get down to business here. What I'm going to try and do is give a fairly short/simple step by step of what I do to get my benchmarking partition up and running. This "guide" is going to be assuming that you're sitting in your main partition ATM and have taken no steps towards prepping your system for any of this. Well then, shall we?
1: One way or another, create a 5GB partition on your hard drive, placing it after your main C: drive on the disk
2: Make sure you either have an install cd for WinXP with SP2 integrated, or have the SP2 isntaller handy
3: Format the newly created 5GB partition (NTFS) and begin to install WinXP
4: Make sure to unplug your network cable anytime during the initial installation of WinXP...as we're not going to be making use of it, and I have still managed to get virus' on my benchmark partition from simply plugging in the cable but not installing any LAN drivers
5: Once XP is finished installing you're gonna want to install SP2 if you don't/didn't have it integrated into your install CD.
The following steps will be a relatively "short and sweet" step by step of what to install when, and what services/features to disable within XP.
1: Install your motherboards' chipset drivers only, no sound or LAN drivers needed here
2: Install your video card drivers
3: Install any third party program needed to overclock your video card if the feature isn't bulit into your drivers
4: Install any/all of your benchmarking programs that will be made use of
5: Click on Start -> Run and type in "msconfig"
6: Click on "startup"
7: Make sure that you don't have a single thing checked off in the "startup" list
8: Click on the "Services" tab
9: Click "Disable All"
10: Sort the services by name and check off the following services to run on startup:
- Event Log
- Plug and Play
- Remote Procedure Call (RPC)
- Windows Management Instrumentation
You might even be able to get away without "Plug and Play" but I haven't tested it out as of yet. Also, if you're using an ATI video card there will be one or two ATI related services on the list that I have also not experiemented with, but will be tonight......so for now I'm leaving them checked.
11: Click "Apply", and restart your computer
12: Open "My Computer" in the start menu and click on "Properties"
13: Click the "Advanced" tab and then under Performance click "Settings"
14: Select "Adjust for best performance" and click on "Ok"
15: Click on Start -> Run and type in "gpedit.msc"
16: Looking in the main window, double-click "Computer Configuration"
17: Double-click "Administrative Templates"
18: Double-click "Windows Components"
19: Double-click "Windows Messenger" and make sure both options are set to Enabled
At this point you should be more or less ready to defrag the partition and start benching. Not that it helps out scores at all, but I usually go ahead and set my start menu to "classic" and simply it as much as humanly possible...as well as uninstalling any windows components I know I'm not using...just because.
By this point I usually end up restarting into my benchmark partition with a commit charge on boot of about 42MB or so, which will help you out, especially in cpu/memory dependent tests like 3DMark2001 and even things like SuperPi times.
I can't recal exactly how much I did end up gaining in some of my tests from this entire process, but seeing as it DOES give me a fairly decent boost in everything except 3DMark03 and 3DMark05 I'd say it's worth the time. Also, this way if you do manage to somehow fuxor your XP install while overclocking (which I HAVE done) you can simply boot off your XP cd and do a repair install, or just go back to your main partition for awhile if you want to, as opposed to having some downtime while you get your main partition back up and running.
I hope this can be of SOME help to some ppl that are maybe as much into the benchmarking scene as I am.....as it's been fun toying with this whole process and perfecting things for awhile, and it's something that really should be done if someone is looking for the most they can get out of their systems.
A note though, once you complete any 3DMark runs in this benchmarking partition, you'll have to be sure to save the project, so that you can load it up in your main partition to submit it.....this way you never have to install any LAN drivers...and better yet, no Anti-virus programs sucking up memory.
Also, one last thing.....for those of you running A64's.....you should REALLY use this seperate partition as an opportunity to install Windows 2000 if you have it...because it IS the faster operating system for AMD rigs...although some of the above steps may not then apply......the OS itself is/will be a better choice over WinXP for an AMD benchmarking rig.
Have fun guys, and be sure to post up any suggestions or questions you might have.....but flammers or thread crappers need not apply.
- Event Log
- Plug and Play
