Mike2007x86
- Apr 27, 2007
How to setup 5.1 properly in vista 64-bit?
My 5.1 worked fine under xp, but I have never been able to get it to work on vista.
If I use the default speaker setup is plays everything all wrong
I also use DDL & DTS Connect for XFI which sets my reciever on constant dolby digital for when I stream movies from the internet onto my wide screen tv. Without DDL and DTS connect dolby digital only would turn on when I played a dolby digital enhanced dvd on the computer.
Streaming media vs regular media:
Is DDL & DTS Connect dolby digital truly outputting 5.1 properly?
You see I have all of my movies stored thru amazon unbox, but I have been considering changing to itunes, since they now offer hd content. If I knew my DDL & DTS connect was properly converting the Amazon unbox 2.1 48Khz audio stream to 5.1 I wouldn't even be considering switching.
XFI Entertainment Mode: (Default)
CMSS-3D (Surround Button) - Stereo Xpand which sets my speakers all the way to the fronts and makes various sounds come out the wrong channels when gaming.
Maybe I don't have this setup right, so please tell me how to make 5.1 work properly in vista and playback correctly thru my reciever.
CMSS-3D (Surround Button) - Change to Stereo Surround
Set the Stereo Envelopment to approximately 50%
I get a type of surround sound, but its not really that effective.
Is 50% on stereo surround the proper way to setup surround sound when using a digital coax to playback movies on a widescreen tv? I no longer use any analog cables.Here is my exact settings as of right now
Speakers 5.1 - Speaker Volume at 100%
EAX @ 12db (None)
CMSS-3D (Stereo Surround at 50% for fronts and surround sound)
XFI Crystalizer at 50%, SvM is turned off, EQ Flat,
Dolby Digital (On for External Decoder, Full Dynamic Range, Dolby Pro Logic is On, Dolby Digital Ex is On), DTS is On to External Decoder ( DTS EX Matrix 6.1 is set to On), and Encoder is set to (Dolby Digital Live - SPDIF Out), DTS Connect - (DTS NeoC and DTS Interactive is another encoder option, but I have never even used it)
