GreatestOne
- May 15, 2005
I have 3x7950 in my main rig. The mb is in my sig.
I am using extender/riser cables on 2 of them... and the one in the middle is inserted directed into the mb.
The riser cables are 1x to 16x.
For some reason, the "primary" card for my monitor usage is the one closest to the CPU, one of the two that uses the 1x. When I plug my displays into the middle one, my displays never turn on at reboot.
It seems using the 1x for my 2560x1440 is not working so well... its fine for everyday work, but PS runs real slow, SC2 lags horribly even when I just get a skype/teamviewer popup, and I get pixelated errors across my screen when I have cgminer running (cryptmining) even at like 60% capacity, which it shouldn't if I were using the 16x I assume.
So how do I "set" the middle card inserted into the 16x in my mb as the main card to display the primary content to my hi-res display? I only have one other display plugged in, a 1080, into the middle 16x GPU.
