Setting Dividers on a DS3
Cintirich
Hi folks,
I'm working on my first overclock with an E6300 and I've hit a wall and I'm not sure what to do next.
I ran 12 hours stable on Orthos last night at 3.115Ghz but when I try to push it past that, Orthos fails within 15 minutes. I'm wondering if I'm at my memory limitation and someone said that I can check this by going to my last stable cpu speed and start adjusting my memory divider to see how far it will go.
On the DS3 board, it doesn't give me options, it just has me enter a number. I had it set to "2" to start, based on someones reccomendation. If I want to start pushing just the memory higher, how would I go about doing that?
My system specs are listed below. Thanks in advance for any assistance?
Okay, I'm a n00b and messed up. It does give you options. It gives you the auto option and then starts at 2 and goes up in .5 increments. In Easytunes, when I tried to lower the Ram speed, it dropped it 670, I'm assuming it's using a 1.5 divider that you can't see in Bios...it made my system totally unbootable and I had to clear the CMOS.
Any idea why that would happen?
