Setting CPU Affinity when running as a service
avey
I'm running F@H on a bunch of P3 Dualies.
How can I set the CPU affinity when running F@H as a service?
Or does it even matter?
Thanks,
When you set it up, select yes to edit advanced options. For the first one, do ID1, secon ID 2, etc..
affinity doesn't really matter with F@H... I'm pretty sure that it's been shown there was little to no gain in setting affinity on dual processor boxen... But what poddo said is correct, if you run more than once instance, you need to set the machine IDs (1-8) accordingly....
Keep on Folding!! For the [H]orde!!
And make sure they are installed into their own seperate folders
Program Files\F@H1\
Program Files\F@H2\
Ya I have the machine ID's set and its installed in two folders.
Cool I wasnt sure if there was a performance gain or not sounds like there isnt one.
Fold on !
correct.... the machine ID is a F@H thing.... affinity is an OS thing....
Keep on Folding!!
right. So this whole tread is very missleading. Setting machine ID will not effect the affinity at all.
right... Affinity and machine ID are completely unrelated....
Keep on Folding!!
The important thing is for more than one console, you need unique ID's, F@H figures out how to use all the CPU power out on its own. There is no need to worry about affinity.
