setpoint issues
forrehmmnd
I have a logitech G7 mouse and have lost the original driver disc, i downloaded the setpoint drivers/software from logitech and it installed and runs fine. the problem is there is no my mouse settings so i can use the side button or set custom sensitivity which i rely on for css.
Its like the mouse isnt recognized by setpoint. help would be appreciated
Try this.. don't know if it will work, but it's worth a try.
Uninstall your existing drivers, and re-boot.
Download these drivers (assuming your using XP) and install them, and then re-boot.
That should do the trick... I think.
Good luck.
