Seti Stats................
klaatu51
I understand that most people here are folders, but a few may have run SETI back in
the day and just wanted to let them know that the stats page has been updated and
apparently includes everyone who registered for the project. In my case there were
2736 in the class at the start, but only about one hundred in the end.
As for folding, I am just getting back and noticed there seem to be two little 'clocks'
at the bottom of the display page. Is this a new wrinkle or have I set things up
incorrectly?
klaatu51
The little 'clocks' are clearly showing the percentage of work done but that would make me
think that I am running two copies of F@H but I am not......unless I have somehow
loaded two work units.
I can't seem to copy the image so I can't explain it any better. Thanks.
klaatu51
are you using the graphical client? becuase i think it has clocks at the bottom corner if i remember correctly
That sounds like the graphical client. If that is the case, the two little pie charts show completion amounts on the current frame, and overall completion for the entire WU.
Just as a suggestion, you might want to consider the console client, as its a little more stable piece of software, and use monitoring software such as EM3 that can tell you all sorts of information about what you're folding.
Console client instructions are here: http://www.hardfolding.com/index.php?go=4
And EM3 information can be found here: http://www.em-dc.com
And welcome back!
