set bios settings to auto, now pc wont boot
jhoo
i posted this same thread on asus's forums, but i will probably get better support here
mobo is asus m2n4-sli (turned out to be a big mistake going with this board)
this is a ram voltage problem im sure as the shitty mobo only supports up to 1.95v
while playing games i would get random blue screens for no apparent reason, so i went into my bios and set everything to auto thinking that would help
well, it didnt help, it screwed everything up
my ram is OCZ gold ddr2 800 2 gigs 2x1gb
i bought it from newegg because it was 1.8v or so i thought, turns out newegg had incorrectly listed the voltage for the ram, so i RMA'd it and they sent me back some ram they tested at 1.95v and it worked, but it only worked because i had already manually set the voltage to 1.95 before i sent the ram back
so i set the ram settings to auto and now it will not boot!
with both sticks in it gave me a ram beep error (one long, two short beeps)
so i removed one stick and it started up, it shows the asus splash screen and just hangs there forever
i have reset the cmos and it still hangs
i have managed to get a little farther by putting the ram in slot 2 or 4, when i do that and i hit del it says entering setup.... and just hangs there
one thing that allowed me to actually get into the bios was to remove the cmos jumper competely, after i did that i got into the bios but i couldnt navigate or anything, so thats not a solution
Having a stick of standard 1.8 volt 533 ddr2 is about all i can suggest to boot into the system and make the voltage and timing changes with, then insert the ocz. I have my old pc that uses this type of ram that i can use to do this with if i run into the same problem.
damn... thats exactly the reply i didnt want to see :(
unfortunately i dont have any other computers that use ddr2 ram
friends?
