Darkstar850
- Feb 18, 2004
I have a server running SBS2k3 that is running low on disk space. It has not reached the critical point yet, but I want to start planning to increase capacity. Currently it has 2 36GB 10k SCSI drives in Raid1, split into a 10 gig OS and 24 gig data data partitions. I keep having to move stuff off the OS partition, and I am down to 8 gigs on the data partition.
The server is a Dell 1600SC, and has a Perc/4 SC scsi raid controller. The new storage area would be mainly for user documents, etc. There are currently only 5 users, and no plans to expand that significantly. I would keep highly used apps and the exchange stores on the primary disks. From what I can tell I have 2 options:
1. From what I have read, I can add more disks to the Perc/4 and create another array.
2. Purchase a SATA raid card and 2 disks.
Please give me your opinion on which option you think would be better, and why. Also, if you choose #2, what would be good hardware choices. I have been doing some reading, but I am not so up on storage systems. Thanks.
