.......The problem came only on 810x WUs......
Agreed. Dr. Kasson was relatively on top of everything given it was the weekend. Much better than days of old, communication was there even if it could not be instantly fixed.Say what you want, I actually like the way this issue has been handled.
Infinitely more professional than ever.
I've had two 8101's go bad for half a million points. I'll let this one finish and if it fails, I'll be shutting down my folding rigs until Stanford fixes their "problem". My latest one just failed this morning.
freeloader1969 what do you mean by failes, are you getting the server has a problem wit the unit message or are they getting eue errors ox8b erors you should not be getting the server error. If you are it needs to be reported over at the FF they can not fix an issue if they do not know about it. All of the messed up WU's should have been completed by now.
[02:16:55] Completed 242500 out of 250000 steps (97%)
[02:45:20] Completed 245000 out of 250000 steps (98%)
[03:13:48] Completed 247500 out of 250000 steps (99%)
[03:42:18] Completed 250000 out of 250000 steps (100%)
[03:42:31] DynamicWrapper: Finished Work Unit: sleep=10000
[03:42:41]
[03:42:41] Finished Work Unit:
[03:42:41] - Reading up to 64340496 from "work/wudata_04.trr": Read 64340496
[03:42:42] trr file hash check passed.
[03:42:42] - Reading up to 31616784 from "work/wudata_04.xtc": Read 31616784
[03:42:42] xtc file hash check passed.
[03:42:42] edr file hash check passed.
[03:42:42] logfile size: 203100
[03:42:42] Leaving Run
[03:42:42] - Writing 96321256 bytes of core data to disk...
[03:43:14] Done: 96320744 -> 91568336 (compressed to 5.8 percent)
[03:43:14] ... Done.
[03:43:25] - Shutting down core
[03:43:25]
[03:43:25] Folding@home Core Shutdown: FINISHED_UNIT
[03:43:27] CoreStatus = 64 (100)
[03:43:27] Sending work to server
[03:43:27] Project: 8101 (Run 22, Clone 1, Gen 60)
[03:43:27] + Attempting to send results [October 2 03:43:27 UTC]
[04:01:56] - Server reports problem with unit.
[04:01:56] - Preparing to get new work unit...
[04:01:56] Cleaning up work directory
I got the "server has a problem with the unit" last night.
Code:[02:16:55] Completed 242500 out of 250000 steps (97%) [02:45:20] Completed 245000 out of 250000 steps (98%) [03:13:48] Completed 247500 out of 250000 steps (99%) [03:42:18] Completed 250000 out of 250000 steps (100%) [03:42:31] DynamicWrapper: Finished Work Unit: sleep=10000 [03:42:41] [03:42:41] Finished Work Unit: [03:42:41] - Reading up to 64340496 from "work/wudata_04.trr": Read 64340496 [03:42:42] trr file hash check passed. [03:42:42] - Reading up to 31616784 from "work/wudata_04.xtc": Read 31616784 [03:42:42] xtc file hash check passed. [03:42:42] edr file hash check passed. [03:42:42] logfile size: 203100 [03:42:42] Leaving Run [03:42:42] - Writing 96321256 bytes of core data to disk... [03:43:14] Done: 96320744 -> 91568336 (compressed to 5.8 percent) [03:43:14] ... Done. [03:43:25] - Shutting down core [03:43:25] [03:43:25] Folding@home Core Shutdown: FINISHED_UNIT [03:43:27] CoreStatus = 64 (100) [03:43:27] Sending work to server [03:43:27] Project: 8101 (Run 22, Clone 1, Gen 60) [03:43:27] + Attempting to send results [October 2 03:43:27 UTC] [04:01:56] - Server reports problem with unit. [04:01:56] - Preparing to get new work unit... [04:01:56] Cleaning up work directory
Earliest re-issue (that succeeded and) that I know of was at 00:39:31 UTC, Sep 30th.While a single anomaly does not necessarily discredit the above hypothesis, I would be curious to know if you were in fact issued a WU that subsequently failed after someone else was (re)issued a WU which uploaded successfully.
TrueAmaruk said:Agreed for the most part, with a few niggles... For example, pointing the blame at the AS/Stanford didn't sit to well. V7 clients report to assign3.stanford.edu, whereas 6.34 clients report to assign.stanford.edu - this would mean that two different AS, that both communicate with multiple WS, each simultaneously developed the same issue with just a single WS. William of Ockham and common sense both agree that's not very likely.![]()
Agreed completely. They need to work a little bit in that department.Amaruk said:But I certainly appreciate both Peter and Joe looking into the matter, especially over the weekend. Enough to even tell them so,..if they hadn't locked the thread...![]()
