charold
- Sep 7, 2011
I inherited an Asterisk 1.2 phone server running on an old Poweredge 2850 currently spec'd out with, hold on to your seat, dual single core Prescott Xeons @ 3.2 ghz, running 4gb of ram and ASterisk 1.2. I'm using less than 1GB of ram w/out cache, and I never see the load go above 0.2, generally staying at 0.05-0.1 throughout the day.
I'm looking at upgrading to a newer version of asterisk, on slightly newer hardware. I'm on a fairly tight budget with other projects this year, and was looking for any suggestions.
Looking at 2u rackmount chassis with redundant power supplies, easily drives the cost of a new server for just the hardware above $1500. I was trying to stay in the $1000 budget if possible. I was thinking (2) lower end chassis without redundant power supplies, and setting up HA between two servers.
Any high level ideas? I'm open to any outside the box ideas, the main thing is this is obviously critical to the operation of the business being our phone server. I can setup HA it seems pretty easily, so 2 low end boxes was an idea, rather than a much more expensive higher end box with more levels of redundancy.
