Server Rebuild - Where to put current data?
Tyklfe
I need some help folks. I've got a 4x160gb Raid5 that is totally full and it's time to update so I'm looking at possibly 4x WD2500KS drives as the replacement running on the same 4 port RAID card that my drives are on right now.
The problem is that I need a place or a way to stash 480GB worth of *cough*stuff*cough* while I pull the old drives and put the new ones in and rebuild the array.
So my question is this: Do any [H]'ers have half a terabyte free for me to use for a day or two when I finally get around to getting my new drives? Or do you know of any company who's buisness it is to store data for a period of time?
Thanks,
Kyle
- Plug in 2 or 3 of the new drives as stand-alone.
- Copy files from the array to these drives and verify each file copied successfully.
- Break the array.
- Copy the files from the larger drives onto the old drives and verify each file copied successfully.
- Now switch the drives. Newer drives onto the RAID card and the old ones as stand-alones.
- Hook the new drives to the array and create the RAID.
- Copy the files from the older drives to the array and verify each file copied successfully.
- Break the array.
Heh - good Idea - thanks.
The only problem with that is if I have enough sata ports to be able to do it all in one go... but whatever, thanks again.
