Party2go9820
- Aug 11, 2000
OK, so this isn't so much networking related, but I figure you guys have as much experience with racks as anyone so here I am.
Just got a nice HP Proliant 1U server. Set up the software and everything is good. Was good. So I went to install the rails in my Compaq rack and the things don't fit. The length seems good and all but the rail ends want to fit in to square holes. My rack has round screw holes so the tabs on the rails don't fit
When I ordered the server I remember wondering about this as there were several "rack mount" options:
Rack mounting rails
Standard Quick Deployment Rails
Telco Rack [Add $111.00]
Third Party Cabinet Rack Kit [Add $128.00]
Sliding Rails & Cable Management Solution [Add $222.00]
I just figured I'd get the standard ones and if needed order the right ones later. Well its later and now I'm not sure which ones I need. You guys got any suggestions or ideas?
Rack mounting rails
