server rack for micro ITX systems
amrogers3
Hello,
Can't seem to find (they may not exist) a smaller 10U or less enclosed server rack that will hold the smaller superMicro micro-ITX cases?
Installing a small group of servers for my home network and this rack will be in my living room (space is very limited) :( So something that has a shorter depth and quiet would be ideal.
Thanks in advance for the help.
sounds like a perfect furniture mod project, you could make a great wood cabinet for this
Supermicro makes short depth 1U cases specifically for their ITX Atom boards. Fanless sans the power supply and less than 10" deep.
Rear IO: http://www.supermicro.com/products/chassis/1U/502/SC502L-200.cfm
Front IO: http://www.supermicro.com/products/chassis/1U/503/SC503L-200.cfm
Hi Blue Fox, I am currently using the SC502L-200 case. I was looking for an actual small server rack. Can't find a smaller rack that would hold the micro-ITX cases. I love the smaller supermicro builds, if I could only find something that would hold the cases...
You can use small mini itx 1u blades?
Check out that link (Most are 1U, ignore all others that don't apply)
http://www.newegg.com/Product/Produ...esult=True&SrchInDesc=itx&Page=1&PageSize=100
If you're trying to put cases in a rack, good luck. I've never seen that done! Would make for one hell of a build log
I know, if I only had the time... :(
