- Dec 9, 2000
it seems that we have lost hte [H] Logo , so my bookmark changed to the vbulliten logo, so did my tab when browsing [H]!!
than try to reverse the passwords that are stored as hash data.
so people with common passwords are the most likely to get their password figure out.
Rainbow tables, however, are not. And to be perfectly honest, he may have made you switch to a strong password, but mine is certainly vulnerable to a dictionary attack.Fortunately, a while back Kyle made us all switch to strong passwords, so dictionary attacks are useless.
as far as I know passwords are encrypted so there isnt really a way to retrieve them if you hack in. at least I think that is the case.
I would like to know if there is a possibility our passwords were compromised.
either way, you shouldn't use the same password for multiple places if some of those places have important information you don't want leaking out.
People often have things like
Forums passwords
important info passwords
i dont care what happens passwords
et cetera
Glad it is back up [H], a nice format always makes things snappy again!
if hardforum does their password right, there is no method to get the password.
well they can get the blowfish encryption key.
however.
if they can use the blowfish key and make it convert all the dictionary words into the keys and compare the database for the hash.
Even if someone does get your password, what's the worse that can happen? I use the same password for all forums (or most) but I do not use that password for anything else. Worse case scenario someone finds out what forums I go to and gets me banned by telling people off or doing stupid crap. Then I'd contact the admin of each forum to explain what happened. Would suck, but not like someone getting my credit card or something. For forums I admin/mod at, I use a different password.
Spammers getting my email on the other hand would suck too, but I already get like 100+ spam emails per day, and I only get one false negative per month, on average. I tweaked my spam filter quite well and whenever there is a false positive I figure out why it did not get marked, and edit the rules accordingly.
Then maybe you should change your password?
lol im lazy i just use the same password for everything.. but important stuff i just change my login name which i dont use on anything else but those important sites.. a lot easier to remember a slightly modified user name then to remember 5 or 6 different passwords..
and user names are usually easier to view as some sites your seen name is your username, it really isnt hard to have at least 1 or 2 different passwords, add some numbers, special character like
h@rdforums#2010
$myforumpassword$
either of those are not prone to dictionary attacks and would take some time to try and crack versus just
myforumpassword
