interested
- Feb 3, 2006
Edit: Maybe i should have posted this in the "Multiprocessing Systems" forum instead of here?
Hello.
I might be making a server for someone soon and its been awhile since i have made a modern server, as i normally make workstation PC's
Right now I am thinking of making a server using a Supermicro Motherboard.
Possibly this X7DBE board
My question: I was wondering if such boards will work with only one CPU installed?
According to the intel 5000P chipset it will work with either 1 or two cpus.
However I cannot find any information stating if these boards must have both their sockets populated with cpu's in order to work.
I have checked the manual and there is nothing usefull there in regards to this question.
The CPU that I am thinking of using is either ONE, quad core E5310 or dualcore 5140 Xeon.
And then if necessary i will add another identical CPU in the future ( assuming it will only work with one alone for the time being)
So anyone out there use one of these server boards with only 1 cpu?
Also I would appreciate any recommendations on similar boards, with the following specs
- use the 5000p chipset
- Dual/Quadcore ready
- dual physical CPU's ,
- Use SATAII with RAID, or SAS/SATAII w RAID, and NOT U320 SCSI
- Extended ATX (E-ATX) form factor which will fit in a 4U/Tower Chasis.
Thanks.
Hello.
Thanks.
