> Server
- $700
3) Where do you live?
- Ontario, Canada
- I need CPU, RAM, Case, PSU, integrated video card on motherboard, maybe 2 TB drives in RAID
- Not re-using any parts
6) Will you be overclocking? - No its being used as a server
7) What size monitor do you have and/or plan to have? 20" LCD
8) When do you plan on building/buying the PC? now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc. RAID.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Windows Server 2008 will be installed
Please suggest parts from www.canadacomputers.com
Basically a server pc is required for shared access to file repository so 1TB or 2TB in RAID is ideal
> Server
- $700
- Ontario, Canada
