Hi,
so I power cycled my server and like the old rule in the book, if it's been running don't touch it, so it broke.
I have Supermicro X10SAE mobo, E3-1245v3 CPU and 16GB of ECC RAM. The server worked well for 2.5 years but now here's what happened:
I turned it on and I got a whole mess of beep codes, and they changed as I started unplugging everything.
Short beeps for all:
2, 4, 5, 4, 3
then it changed to 6, 9, 3
then it changed to 3, 3 and is now permanently stuck beeping 3, 3 long pause 3, 3, etc
Supermicro does not list these beep codes. I now only have 1 memory stick, CPU w/fan and Mobo working, everything else including all the extra fans disconnected. I pulled out the RAM and the code changed in frequency of sound and number of beeps to 5 short and 1 long, which is what I expect, so it's not a RAM problem.
It's not a PSU problem, I swapped it out with another one, same issue.
Can't really replace the CPU or Mobo since they both cost ~$250 each in order to troubleshoot.
Would be nice to understand what those beep codes are...
2, 4, 5, 4, 3
