Mackintire
- Jun 28, 2004
So I built and tried to deploy a server 2012 WSUS and its not working right.
Installed Server 2012 and added the server to the domain with no issues.
changed the server to a static IP address and created a new record so that the IP resolves correctly and NSlookup functions.
Added WSUS role which also added IIS and a silent install of SQL 2012 Express WID Database automatically.
The domain is running 2008 R2.
Added a group policy for WSUS and pointed to the server at HTTP:\\servername:8530
Now here starts the problems.
When I first set up WSUS everything appeared to work and both machines that I added to the WSUS via GP showed up fine.
Now both clients have a 0x80244019 error while trying to connect.
I finally got my one client to connect by changing the address twice, but now WSUS shows 13 updates available and none of those are showing on the client when I run windows update. The WSUS console shows that my one client is connecting, but doesn't offer updates.
Running Starwinds WSUS tester shows either a proxy issue HTTP issue or some sort of IIS issue.
I removed all the relevant roles from the machine rebooted and added them, but all the settings were remembered correctly.
Trying to look for WSUS 4.0 help online is close to useless.
I'm close to considering blowing it all away and starting over from scratch.
Any ideas? And good tools? Ways to verify the configuration step by step to find the fault?
I'm thinking the problem is IIS.
Any help would be greatly appreciated.
