Server 2003 vpn login problems
schdr
Ok heres the problem... I had Vista setup as my vpn as per these instructions
http://theillustratednetwork.mvps.org/Vista/PPTP/PPTPVPN.html
Which worked perfectly. However I needed to have more then one income connection. So, I setup a server 2003 box and setup vpn with the rras wizard. I believe everything is setup correctly. I also went in to the user properties and set the user to allow dial in. Now when I try to connect the vpn client stops on verifing user name and password, and then recieves a error saying the server didn't respond. On the server I am getting this event error.
Event Type: Warning
Event Source: RemoteAccess
Event Category: None
Event ID: 20049
Date: 8/19/2008
Time: 8:11:39 PM
User: N/A
Computer: SERVER
Description:
The user connected to port VPN3-127 has been disconnected because the authentication process did not complete within the required amount of time.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
I have port 1723 forwarded and GRE enabled. It was working with Vista as a vpn host so I am assuming its something to do with the server and not the firewall.
Help!
