- Sep 6, 2007
I'm redoing my backup processes at work, and I want to take one final, manual snapshot of an SQL Database before I make any changes. I realize, that simply copying the files in question isn't going to work, because they are in use. My question is this: Is there a quick set up steps, or commands to shut down the SQL services, make a simply manual copy of the files, and then restart the server or services?
The three files I need are of the types .ldf, .mdf, and .ndf. This is a standard 2003 Server, and SQL Server 2000 Standard, if that matters.
Any suggestions? I know I can right-click on the SQL Server icon in the system tray, and choose either STOP or PAUSE. I'm worried about this corrupting the database though. No one is using this system, so is it safe to just use those options to stop the server, copy my files, and then start up the server again?
