When I ran a disk cleanup on my system, on my data drive it is showing 50GB of compressed old files. I never compressed anything on my system, now all of a sudden I have a huge amount of compressed files showing up. I dont want to delete anything because I dont know what files it is talking about that are compressed.
when I click on the compressed old files folder under disk clean up it tells me that windows does this to files that are not accessed for awhile. when I click on options for the compressed old files it shows that it is set up for files that have not been accessed for 50 days to compress them.
Is there any way to turn this off?
This is the same way that it shows up when I right click on one of the compressed files and this is the process to compress/uncompress the files.
http://www.windowsreference.com/windows-vista/how-to-use-ntfs-compression-in-vista/
I called a friend and he had me run the compact /u /s /i * command in the dos prompt and it said it was decompressing the folders but when I re-run the disk cleanup utility it still shows the same amount of compressed files.
