serious problem...really need help!!?!?!!!
Shuey
:confused: hi guys,
i came back home from vacation and when i hooked up my desktop computer again, my monitor didnt turn on, it went into its standby mode showing a light orange light. Now, my monitor is fine, and my video card is a 9800radeon pro and i just purchased it a month ago. SO i thought my bias was corrupted. currently im running with a Asus A7V8X-X and have an amd ath. 2600+. I tryed resetting my motherboard by taking out the battery, and the motherboard chip but still my monitor fails to respond. Also, i tried to pull out my ram to see if there would be a beep code and there wasnt. But the wierd thing is that all my fans turn on and all my cd rom drive opens and stuff its only my monitor, and my mouse that doesnt light up...
does anyone kno what i can do to fix this,...?
thanks guys,
shuey :(
It's kinda odd that there's no beep code, make sure the case speaker is connected to the motherboard. Also try taking out the videocard completely and putting it back in. It might not be seated correctly.
Test the vid card in a known good system. I'd also consider resetting the CMOS on the mainboard, and possibly (if worst comes to worst) reseating the CPU, and remounting the CPU heatsink/fan. If for any reason the CPU burned up (was it operating while you were away, or fully disconnected?), your system might not beep.
