Serious Error. (got 3 on a restart)
DRJ1014
Today i was updating my windows media player. after it was done installing it asked me to restart. i clicked restart. when it restarted i would try to play somthing with winmedia and it would say installed improperly restart. i restarted. still it did it. i thought well i better uninstall it to see what happens. so i went to add remove programs and found this windows media hotfix thing. i uninstalled that. it restarted my computer automatically. i didnt think anything of it until it wouldnt load windows. i would get the windows professional screen with the blue bar and then it would go black. it did this about 3 or 4 times then i turned it off. i came back it asked me to start in safe mode, normally, comand prmt or best known command. i did the best known command and it loaded. when it loaded i got 3 serious error reports.
what did i do?
Did you check details on the errors?? Are you still having problems???
