I was so close to finishing my HTPC build, when I realized that I simply don't have the clearance for the 2 6-pin PCIe connectors going towards my HD 6950, since they are facing up.
So, I took them out of their casing and connected each pin separately to the card.
But even that isn't good enough!
So now.. I have two choices. Either I solder the cables directly onto metal rods on the card, by removing the plastic casing.
Or I cut the PCIe pins in half, and instead of the usual crimping the wire onto the connector, I will solder it.
Only question is - will the latter even work? It should, right? As long as the wires are touching the end connector, it will work...
