I'm building inside of an AeroCool ExtremEngine 3T. All was going smoothly until I tried to slide my video card into place. The metal tab on the end (that you put the screw through to hold it down) is hitting the edge of the case before the card is able to slide all the way into the slot. If I push the card all the way down, the far end of the card goes all the way in and then slants upwards, so that the end nearest to the edge of the case isn't quite in. I haven't turned it on yet, but I'm assuming a video card installed on an angle simply won't work.
Any suggestions on what to do? I really don't want to have to RMA this case. Removing the metal tab would be hard and if I did that, the video card would be very unsturdy.
Thanks for your help.
